Help me diagnose a clacking sound from rear
  • iamsam
    • Jun 2008
    • 176
    * Update w/ pics, see post #23 *
    Background:
    1991 318is, H&R Race, Billy Sport, Kosei K1 15x7, IE billet alum RSMs, 210k miles, rear seat removed, rear carpet removed, all trunk carpet and spare tire removed, ski hole plate removed, so I hear everything.
    Symptoms:
    A loud clacking sound has very recently developed from the right rear when I drive over harsh but small bumps. Sounds like it is coming from in the trunk, not a dull thudding from the subframe or something. Seems to happen when the suspension is jarred, rather than long and smooth suspension travel. I hear the clacking from inside the car w/ the windows up. I can't replicate the clacking at all by jumping up and down in the trunk.
    Attempted fixes:
    Adjusted the trunk so it shut snug with no play, took off rear right wheel to inspect, bent the brake dust shield back into place. It isn't the RSMs, they are in great shape. I assume the bushings are original, and shot.
    Suspected diagnoses:
    Could be bad subframe bushings. Do bad bushings make this sound? There may be something loose in the battery tray, but it doesn't really sound like that kind of noise.
    Can anyone help?
    Thanks guys.
  • iamsam
    • Jun 2008
    • 176
    this sounds like a similar problem: http://www.r3vlimited.com/board/show...frame+bushings
    • barry
      • 1642
      Check Differential bearings etc. also half shafts.
      • iamsam
        • Jun 2008
        • 176
        as in tear apart the differential?
        • barry
          • 1642
          Jack the car up and move the wheels or start car and run the gears, listen and feel for slack etc. also check calipers for loosness etc. Do you have a loose jack in the trunk banging against metal or loose gas tank or muffler strap.
          • iamsam
            • Jun 2008
            • 176
            there is absolutely nothing in the trunk at all except a battery. You guys don't think it could be bushings?
            • barry
              • 1642
              The bushings are easy to check, use a crow bar to check for movement. Half shafts will clack if the big ball bearings are worn, checK and see if the CV boots are ripped.
              • iamsam
                • Jun 2008
                • 176
                Will try the crowbar approach. The CV boots are dry rotted slightly, but not ripped. How can I test for bad CV joints? Keep in mind, this is a clack that I hear clearly from inside the trunk, almost as if something is smacking metal literally in the trunk, and the sound comes into the cabin through the ski hole.
                • barry
                  • 1642
                  Sounds like half shafts to me. Jack car, start motor and you'll no right away. make sure both wheels are off the ground. Rememeber the differential connects right in the middle of trunk. Do you here the noise when turning under speed sharply? Could also be drive shaft joints, most of these things can be hand tested.
                  • iamsam
                    • Jun 2008
                    • 176
                    the clanking is bad when I am going over bumps on a hard right turn. how do I test the half shafts? Just run the car in gear w/ the rear wheels jacked up? how will I know right away? I jacked up one wheel and ran the car in first gear (open diff) and there was no noise.
                    • barry
                      • 1642
                      Listen find a parking lot and do 360's both left and right If there is no clanking you may have a broken shock. If it only happens going over bumps somthing is loose or broken. Also check differential and Tranny mounts.
                      • Ryann
                        • 3350
                        are all your exhaust hangers intact?
                        • 619E30
                          • 1753
                          Loose muffler?
                          Originally posted by audiquattrot
                          bimmers b4 b*tches....remember that.
                          1990 Alpinweiss 325i - secret 500whp build
                          2000 Audi S4 B5 Laser Red
                          1990 Nissan 240sx - Drift Missile
                          2006 CBR600RR
                          • E30_fiend
                            • Apr 2006
                            • 7348
                            I think I may have the answer to your problem. Go ahead and check the brake caliper bracket bolts. They are known for backing out at least I have seen it happen a few times. Caliper bracket bolts arent something you usually think to inspect and also they are easily overlooked when inspecting CV boots and the like. Check that then check back.
                            Taylor
                            • iamsam
                              • Jun 2008
                              • 176
                              I'll have to try this. I know the diff bushing is on its way out, and i'll have to check all the bolts to see if any have backed out.
                              Originally posted by 619E30
                              Loose muffler?
                              I don't think so, I installed a new muffler about a year ago, but I will check
                              My right rear brakes are wearing the rotor funny, has been doing it since I bought the car, the brakes seem only to be contacting half the rotor....
