what's the best way to test coils on 318is M42?
    I've got a '91 318is, today I got in it to run up to the store, and it started + ran fine for the first mile or so, then it began to run rough, and was really down on power. I continued to the store, but had to feather the throttle to get the car to accellerate, and it continued to run poorly, down on power.
    I popped the hood and checked the plug wires to make sure they were all properly seated, and they were OK. I could not find anything loose, no bad vacuum leaks. I noticed some smoke coming from under the car, and saw the side of the cat was glowing slightly orange!! I'm guessing either the cat failed, or one cylinder is not getting spark, so the unburnt fuel is getting caught in the cat- making it get REALLY hot (this may be the cause of the cat failure).
    Anyone have the test specs for these coils?? Anyone have any ideas on how to figure out if it's the cat that failed on it's own, or something that caused the cat to fail or ?????
    I've got a couple of spare (used) coils to use for troubleshooting, but the next step is to pull the plugs + see what they look like (I'm waiting for the car to cool down now...)
    Bret.
    I used to have my brother hold onto the plug wires while I cranked it. Probably doesnt help you much but it was damn funny!
      ....wow your a fucking bastard.
      '91 318is
        no kidding, i dont believe you did this cause i dont think anyone is that stupid but if you had you could'v killed him
          Voltage doesnt kill, amperage does.
          Aaron
            woops clicked twice by accident
              i think everyone knows that but you only need 3.5 amps to kill somone or 3.2 or 2.3 not really sure which
                Rig, those coils usually go bad "VISUALLY".. what I mean is this, pull the trim cover off and visually inspect the coils to see if they've Cracked.....that's usually what they do when they die, expand and break the insulation
                Man, you delivered karma to her scalp
                  Aww Bullshit! A bosch blue coil wont do shit! The funny thing was he fell for it several times!
                    you must have a verry stupid brother
                      probabally runs in the family.
                      '91 318is
                        sounds like it
