Reuse front wheel bearings?
  • Wh33lhop
    • 11705
    I've got some new strut casings that I have some plans for, my old wheel bearings are fine, no noise or play, and while I like replacing stuff, I don't really feel like shelling out $200+ for new bearings/hubs for the front. Has anybody reused old wheel bearings, or is it a crap shoot that the races don't separate? Should I even bother getting a puller, or just shell out for new bearings?
    paint sucks
  • AndrewBird
    The Mad Scientist
    • 11897
    When Josh and I replaced his, the bearings just slid off the spindle once the nut was removed. No puller needed.
    As long as you don't pull the inner race out, the will be fine.
    • 619E30
      • 1753
      give them a try
      Originally posted by audiquattrot
      bimmers b4 b*tches....remember that.
      1990 Alpinweiss 325i - secret 500whp build
      2000 Audi S4 B5 Laser Red
      1990 Nissan 240sx - Drift Missile
      2006 CBR600RR
      • Jean
        • 18228
        I did for now, one side slid out complete as one unit and the other separated.....FTL. Re-use them and keep an eye on any noises and then replace with new...
        • StereoInstaller1
          GAS
          • 22679
          Fuck it man, this isn't rocket science.
          If that inner race pops out, put it back...just know you are gonna be doing it again in a couple of months.
          Closing SOON!
          Thanks for 10 years of fun!
          • Wh33lhop
            • 11705
            Eh, I'm new to bearing work. Just being cautious, I don't want to try and pull a bearing, then separate it and be out a car until I get a new one. As I understand it, if you separate a bearing it's pretty much ruined.
            I might just use new ones, but I hate replacing expensive shit that still works fine.
            paint sucks
            • StereoInstaller1
              GAS
              • 22679
              I ripped mine apart, but after brutalizing it back together, it still feels fine a year later, like 8,000 miles last year.
              Closing SOON!
              • IDM
                • 753
                Just clean them and repack themput the seals back in. If you don't see apparent damage/markings on the ball bearings they are probably fine.
                • AndrewBird
                  The Mad Scientist
                  • 11897
                  As long as you don't mess up the inner bearing cage (the thing that holds all the balls in place) you can put them back together and have them be fine. Just clean everything very well, re-assemble and pack them with grease. And by pack, I don't mean smear some on the outside of the bearing. You need to pack the grease into one side until it comes out the other. Basically the same idea as this:
                  Only that is a needle style bearing and e30's have roller balls. You also don't have to move as fast as that guy did.
