Pics of battery mounted in trunk please
  • BDK
    • Jul 2008
    • 684
    I am getting ready to move my battery to the trunk of my cab and I am looking for pics of the battery sitting in place and how the wires run from the factory, any help would be appreciated...
    Thanks,
  • StereoInstaller1
    GAS
    • 22679
    Dude, I spent a bunch of time trying to figure that one out.
    the issue is the route from underhood to the trunk. The stock wire run is covered by a welded in plate, meaning you will have a hell of a lump of wire running under your carpet on the left.
    Closing SOON!
    Thanks for 10 years of fun!
      The power wires a run from the firewall connector block in the channel under the door sills then through the rear bulkhead to the battery.
      • StereoInstaller1
        GAS
        • 22679
        Exactly, but 'verts have a plate welded in the entire length of the sill, so you cannot run wires there.
        Closing SOON!
          That makes sense since a 'vert needs the battery up front for weight balance.
          • Duct_Taper
            • Jan 2009
            • 28
            I always see people saying that the verts got the battery under the hood for weight balance... but if that's the case, then why did BMW put a big cast iron weight in the trunk of the verts where the battery would have been?
            • dinanm3
              • 176
              I didn't know the verts have battery under hood.
              My 1988 325e non vert battery is in trunk .my e36 m3 battery in trunk.
              my 2002 1972 i need to put battery in trunk they came under hood.
              • jeffw
                • 1087
                as far as I know the verts and the early 318s are the only ones with the battery under the hood. not sure about the late model 318s.
                • jeffw
                  • 1087
                  is that accurate?
                  • StereoInstaller1
                    GAS
                    • 22679
                    I can't remember if the M42 car has it in front or not...
                    Closing SOON!
                    • e30nub
                      • Jun 2008
                      • 1741
                      M42 has it in the rear.
                      -Pierre
                      1987 535is
                      1988 325is
                      • jeffw
                        • 1087
                        i wasn't sure about the m42 either. so it is the verts and early 318s
                        • StereoInstaller1
                          GAS
                          • 22679
                          That door sill plate was welded on for strength, so the weight had to be added back there.
                          that weight isn't just a lump of metal, it has a harmonic reduction function too.
                          Here is that welded panel (shown with my assistant):
                          Closing SOON!
                          • Dominic49
                            • Feb 2007
                            • 1373
                            teaser
                            • accident
                              • 7303
                              mmm, assistant.
                              Moral of this story?
