Adjusting your own valves..
    If I hadn't, it would have been impossible. I'll get pictures showing where the hose went, it was the valve cover breather hose (I'm sure most of you know where that is anyway)
    Cranking the engine is VERY easy without an LSD. I just lifted up my right rear tire, put my manual transmission in 5th and turned the tire - I'd turn it little by little until the pair of valves were closed - aka top dead center. I learned a shit load about my car doing this... ;)
    If I didn't have lsd...I would have had to lift the front of the car up, and crank it some the crank thing in front, whatever it's called. It would have been really tough. Also, my spark plugs were removed, with those in, it would have been much harder to crank the engine.
    Last night I also changed my oil, running Mobil 1 15w-50 now - it is TONS quieter then when I was running 5w-30 - seems a lot smoother too. I love it. :)
    - Sean Hayes
