What the sheep shit?
  • mamzak
    • 883
    What would cause a battery to be completely drained within a matter of 10 minutes as the engine is running....aside from a bad battery?
    All girls fuck but not all girls fuck around with combustion engines.
  • Holland
    • Nov 2008
    • 7178
    Bad Alternator?
    Originally posted by DEV0 E30
    • E30Nova
      • 1546
      How do you know the battery was completely drained? If everything was working right, the engine would be running off the alternator, so if the engine just died after 10 minutes, I'd look at replacing the alternator.
      Matt
      Matt
      I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
      Originally posted by kronus
      try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
      This is like a reverse build thread; it starts out nice and gets shitty.
      • mamzak
        • 883
        The engine didn't just die though that's the thing.. I had it running fine and it sounded good but then I shut it off to double check the oil and it wouldn't start back up.
        EDIT: When I started it the first time it cranked and fired up nicely so it's not the starter
        • lonestar22
          • Aug 2005
          • 417
          sounds like the alternator is not charging the battery. and the first time there was just enough juice.
          either that or the voltage regulator is shot. or maybe an alternator wire came loose
          Originally posted by Lof8
          Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.
          • bimmerpirate
            • Feb 2007
            • 561
            alternator or a bad cell in the battery.
            • mamzak
              • 883
              I'm hoping it's the alternator because I already have a new one ordered.
              A fried voltage regulator woudn't kill the battery though would it? It was a good battery I took out of my Winter Beater (Optima Red Top) so I know it's not a bad cell. I tried the battery in the accord after and it wouldn't start up either so it definitely drained it.
              So. 90% sure on alternator?
                My guess is that the battery wasn't fully charged when you put it in the car. That in conjunction with a non-functioning alternator would have drained the battery enough to prevent the car from starting the second time.
                Before replacing the alternator make sure that the alternator warning light in the cluster comes on when the key is switched on. That bulb is a critical part of the charging circuit for most E30's* and supplies exciter current to the alternator. If the bulb is burned out, the alternator won't charge.
                A shorted regulator will drain the battery in short order. A bit of work with a DMM will pretty quickly reveal whether the alternator is working or if the regulator is shorted.
                * Very late production clusters include a bypass resistor to allow the alternator to work when the bulb is out.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  I'd check the engine ground strap. Might be loose.
                  • Burnera
                    • 137
                    optima has also gone down in qualiy a lot in the past 8 years or so.
                    • mamzak
                      • 883
                      I think my date of manuacture is August of 1990... would this have a bypass resistor then?
                        It might. If the bulb works, it is a moot point. If it doesn't a check at the exciter terminal with the ignition on will tell if exciter power is present.
                        • mamzak
                          • 883
                          groovy! Thanks man!
                          • Simon S
                            • Oct 2004
                            • 3758
                            That 'Bond' sig is friggin sweet !
                            -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                            • txtorquemade
                              • 1758
                              Originally posted by simon s
                              that 'bond' sig is friggin sweet !
                              +1
                              sigpic 1987 325is
