Front brake line..
  • redbull 325is
    • 7471
    Front brake line..
    I am in the process of installing SS brake lines and i ran into a little issue... I completely
    stripped the 11mm but on the front driverside brake line.. i tried putting vis grips on it to no avail.. any other ideas? perhaps replace the line from the MC to the wheel well?
    Julien
    Build Threads:
  • kowalski
    • Jan 2005
    • 1791
    you could grind 2 flat spots and put the vice back on and give it another shot, how'd you strip it anyways? or cut the line and reflare it, but for that you need to buy a brake flaring kit. i dont htink they're that much money tho
    • redbull 325is
      • 7471
      good call.. i'll try that out
      Build Threads:
      • kowalski
        • Jan 2005
        • 1791
        alrighty well good luck to ya.
        • T.Dot E30
          • Mar 2004
          • 536
          heat it up with a propane torch.
          Should free it up enough to get it off with a vise grip.
