m20 ticking...
  • 16v of E30
    • 157
    m20 ticking...
    88 325i,
    runs good, idles smoothly, just has a loud ticking sound when accellerating.
    i had the valves adjusted and such...
    whats the common reason for this sound?
  • bmwstephen
    • 2463
    is the ticking at certain speeds when accelerating? I think i have the same issue during initial accel. but goes away once I go past 20mph. sounds like its coming from the drivers side
    • rThor432
      • Feb 2007
      • 3907
      The injectors make a pretty loud ticking noise. Depends on your definition of "loud". Outside of that, it's pretty hard for me to call it without being there and hearing it. They can be pretty noisy engines with lots of "ticking" noises.
      Do you know what spec they adjusted the valves to? While the factory .010" spec should work fine, I've found that adjusting them to a tight* .010" (or even a moderate .009" on my own cars) helps to keep the noise down. I actually think I was running a loose .008" on one of my M20's, but I'm not positive.. Also, the valve adjustment would be skewed if the car was not dead cold when the adjustment was performed. I don't know anything about the shop you went to, so I assume they did everything right. I'm just asking so that you can look a bit deeper into the ticking issue.
      *My definition of loose @ given spec- Feeler gauge moves completely freely although there is no free-play between the eccentric adjuster and valve.
      Moderate- Some resistance felt when removing/installing feeler gauge.
      Tight- Lots of resistance felt when moving the gauge. The clearance is "tight".
      • NC325iC
        • Mar 2004
        • 6565
        time bomb? did you look around for any clocks with wires coming out?
        but in seriousness could be an exhaust leak
        • Leaf
          • Apr 2009
          • 985
          e30 engines tend to tick, oh well.
          • canbedirtye30
            • May 2007
            • 9
            could be a lot of miles and worn eccentrics and or cam...in which case you can never get rid of the tick...ask me how I know....
            • george graves
              • 20003
              How do you know? :|
              Injectors can make a good amount of noise too.
              Originally posted by Matt-B
              • Wh33lhop
                • 11705
                Could be a bunch of things, but M20s (and M30s) are just sewing machines in general, even in healthy form.
                paint sucks
                • bmwstephen
                  • 2463
                  i still think an m20 in need of a valve adjustment is still a whole hell lot smoother than an m52/m54. those things rattle ike crazy with the vanos and chain issues and not to mention the additional accessories on the engine needed to maintain emissions.
                  • enigmaticdream
                    • Jan 2010
                    • 572
                    A m20 with a proper valve adjustment should sound like a sewing machine. If someone says differently, punch them in the face.
                    1986 911 Supercharged Frakenstrat/Stripped
                    1987 325is Delphin/Black (Olga)
                    1988 M3 Zinno/Natur (Elsa)
                    Manual or STFU
                    E30 Chapter of BMW Car Club of America
                    E30 Oktoberfest 2017
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      What oil are you running? 20W50 might help a bit to quiet things down. I've read that worn rocker shafts and rocker bushings can also contribute to more noise.
                      '89 Alpine S52 with goodies
                      • llll1l1ll
                        • 782
                        N/m. Wrong spec.
                        Me: "I can't wait to redline my car!"
                        Mark: "Didn't you just break a rocker arm?"
                        Me: "Yeah, I don't think I've learned my lesson."
                        Mark: "You never will."
                        • Ceeker
                          • Sep 2009
                          • 2821
                          If the rocker arms are worn and or the shafts then you will get pronounced ticking above and beyond normal and especially under load. Change the shafts and arms and you'll be good to go. Just make sure your cam isn't worn either. In most cases when changing rocker arms you should get the cam reground or replaced to avoid prematurely wearing out the rockers.
                          • funcrew
                            • Jun 2007
                            • 1223
                            You can hear the ticking on my M20 a block away, even after valve adjustment. I keep constantly revving it to 7K at freeway on-ramps to try to grenade the motor & be forced into a swap, but that has no effect whatever.
                            "If the sky were to fall tomorrow, the tall would die first."
                            -Dr. Paul Forrester
                            Do I LOOK like I need a psychological evaluation???
                            • Devil Inc
                              • Jan 2008
                              • 802
                              My favorite personal quote for when people ask why it sounds the way it does is, "it's supposed to sound like a singer sewing machine".
