:D First I'd like to thank everyone here and at ulti. bimmerforum for their input, this is truly their list not mine, I just needed it typed up, Thank you. :twisted:
MOTORS
’92-’95 M50: Least expensive motor, most available, needs modification to equal hp of S50, can cost more to modify than just starting with S50, cast iron block, aluminum head, cast iron exhaust manifold.
’95 S50: More hp for less modifications = more cost effective, possibility of valve spring retainer failure before 10/’95, 10/’95 and later has updated retainers, replacement part # same as old part but redesigned, cast iron block, aluminum head, cast iron exhaust manifold.
’96 + M52 / S52: Expensive, OBD-II should be switched to OBD-I, cast iron block, aluminum head, stainless steal headers.
’97-’98 Z3 M52: Most expensive, OBD-II should be switched to OBD-I, aluminum block, aluminum head, and stainless steal headers.
BREAKDOWN BY MOTOR
COMPLETE ’92 M50 (NO HOT MODS)
INSTALL MOTOR AND TRANNY AS ONE PIECE
5 LUG CONVERSION NOT REQUIRED FOR SWAP
• Motronics unit ECU 402 or 403, DME
• E36 Wiring harness, wiring support bracket, E30 318 ECU mount
• Intake Manifold with PCV fitting, PCV hoses (2 with check valve and hose separator), air temp. sensor, vacuum port, gaskets, brackets (pair), MAF and MAF boot
• Throttle Body, (?E36 or E34? throttle cable)
• Idle valve hoses X 2, idle air control valve
• E30 Fuel pump, fuel rail, lines and hardware, injectors, pressure regulator
• Coil Packs with plastic harness X 6
• O 2 sensor
• Camshaft position sensor, camshafts (M3 cam won’t work)
• Zionsville radiator (aluminum) or E36 radiator and ‘89+ surge tank, or '89 + E30 radiator with E36 hoses
• Metal impeller water pump (comes with ceramic - replace with metal)
• Aluminum thermostat
• E30 Coolant temp sensor for the instrument cluster, coolant hoses – throttle body supply with thermal switch, coolant sender
• Hose clamps
• E34 525i oil pan (needs to be shaved and drill hole in pan and bolt to bellhousing), dipstick gasket, oil suction pipe part # 11-41-1-748-150, oil suction pipe gasket part # 11-41-1-703-947, new oil pan bolts (toss old bolts), oil pan gasket part # 11-13-1-437-237
• E36 alloy engine arms, E28 M5 rubber/urethane motor mounts (no spacers), 535i rubber/urothane motor mounts with 5mm spacers or use oval holes without spacers (also 535i)
• E28 M5 or two 320i Tranny mounts, E30 tranny X-member (?all trannies?)
• E30 260 Getrag, E36 manual, or ZF (E36 M3 or 328) Tranny
• Harmonic balancer sensor
• Plugs for exhaust manifold, gaskets
• Alternator
• E36 Power steering pump: Use M10 motor power steering banjo type hose fitting to nut type hose fitting adapter on pump side (E36 pump to E30 hose)
• E30 starter if E30 flywheel and (M20 motor) pilot bearing or E36 starter if E36 flywheel
• All pulleys
• E21 320i brake booster with modified shaft (shortened to 15mm) or E30 325ix/E32 735i as is, E34 M5 or 25mm brake master cylinder with additional brake line if used with E30 325ix booster or a E32 735i with the modified E21 320i booster
MOTORS
BREAKDOWN BY MOTOR
• O 2 sensor
• Hose clamps
• Alternator
• All pulleys
