Hi all,
I have an overheating problem that I cannot figure out.
My car is a 1991 318i with the M42 engine.
The first time I took it on the highway it started overheating once I reached 70mph.
Since then it has progressively gotten worse. Now I can't even go a mile before the engine is in the red.
I flushed the coolant (properly, thanks to the e36 bentley manual). Checked the themostat by feeling the upper radiator hose and its nice and hot to the touch after the engine has been running.
The temperature switch for the axillary fan is defiantly broken and I am "bypassing" it right now by having the air conditioner on (the little snowflake button on the dash pressed in.)
I'm trying to ID what the problem is.
A few things:
1.) Whether I turn on the heat or the air conditioner, the air that comes out is always the same temperature, which is about the ambient temp. Could this be a symptom of my overheating problem or is it a separate issue entirely?
2.) The radiator only gets hot on the side that is close to the reservoir cap. Is that normal?
3.) The lower hose, leading from left side of the radiator to the thermostat housing, stays cool. Could this indicate a block.
I just bought this car and it was fine until I took it on the highway a few days ago. I need it for work so any help would be greatly appreciated.
A few things:
