Where can i buy black len tail light
  • jOeM20z
    • 1
    Like this where can i buy black len tail light Thanks
  • Jordan
    • 12916
    abrahamsmotorsport.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, abrahamsmotorsport.com has it all. We hope you find what you are searching for!
    https://mtechniqueabs.com/
    • kowalski
      • Jan 2005
      • 1791
      you can also do that yourself, if you buy the tinting spray paint and paint and punch a hole in it, do it safley cause it will shoot everywhere or just spray it into a jar, then put it into a paint gun and spray it on, the paint gun because it paints evenly unlike spray bomb which is why that paint isn't recomended but if sprayed out of a gun will work the same. also you can just mix a bit of black into a clear and it will have the same effect except you have to beware of mixing to much otherwise you gotta do it over again. but good luck.
      • PanamaE30
        • Oct 2004
        • 768
        On the note of tail light colors...
        Where can I get some clear tails? Well, just the turn signals clear..
        1988 325iC - "Betty" - Daily Driver/Project Car.
        1993 318i - "The Golden Dream" - Dad's Car.
        1995 318ti - "Hellrot" - R.I.P.
        • kowalski
          • Jan 2005
          • 1791
          same web site.
          • kencopperwheat
            King of Kegstands
            • 14396
            Originally posted by kowalski
            you can also do that yourself, if you buy the tinting spray paint and punch a hole in it, do it safley cause it will shoot everywhere or just spray it into a jar, then put it into a paint gun and spray it on, the paint gun because it paints evenly unlike spray bomb which is why that paint isn't recomended but if sprayed out of a gun will work the same. also you can just mix a bit of black into a clear and it will have the same effect except you have to beware of mixing to much otherwise you gotta do it over again. but good luck.
            You = moron.
            The one's Jordan has are genuine, not that spray tint crap.
            Originally posted by Gruelius
            • finch
              • Oct 2004
              • 279
              i think by saying you can ALSO do that yourself he way sugesting a differant method.
              not implying that jordans were homemade
              • george graves
                • 19998
                Loose jordans sig man, for a second I thought Jordan was answering his own question....
                Originally posted by Matt-B
                • finch
                  • Oct 2004
                  • 279
                  er... :shock:
                  • kowalski
                    • Jan 2005
                    • 1791
                    You = moron.
                    your a retard, i didnt say jordan sprayed his i said you can spray them if you dont want to fork out the cash. if you read what i said instead of accusing me you can realize that.
                    • BMW BMXER
                      • 2325
                      you can also do that yourself, if you buy the tinting spray paint and punch a hole in it.
                      Sold it.
                      • kowalski
                        • Jan 2005
                        • 1791
                        there is a safe way to do it, i duno how but my good friend who paints show cars knows how to do it he does it with the spray on glue he puts it in his primer gun for an even spray. you may just have to spray it all into a can it still wouldn't be that hard to do its still all going to come out of you push down on the nozle and empty it into a gun. or you could just put black in clear i believe if you turn the can upside down and press the nozle down nothing comes out so you depresurize it then it wont explode its not a hard concept to think up...
                        • Madhatter
                          • Oct 2004
                          • 966
                          There is paint you can buy to tint clear plastics, it's called niteshades down here.
                          Just a little project im working on
                          - http://www.lse30.com -
                          • kowalski
                            • Jan 2005
                            • 1791
                            yeah but it comes in a can right? and can's spray uneaven and for a tint that looks bad which is why people dont use it so if you drain the aresole and then cut it upen and empty into a spray gun you have a nice even spray.
                            • Bavarian3
                              • 1230
                              It depends on how you want your tails to look...
                              Alot of owners like to DIY tails, which on the internet look great, but cameras can make a lot of things look great.
                              Some don't like the early tails due to the 'purplish' color, which is fine. But if you are going to tint your tails your self, take your time and do it right. I would recommend also searching this site, since this subject has been posted quite a lot.
                              Hope this helps...
