Conn. Rod seperation from Piston?
  • akinswonder
    • Nov 2009
    • 177
    I have been looking everywhere and I can't find any info on how to seperate the conn. rod from the piston. I just removed mine from my m20b27 block, and I'm having trouble getting the rods by themselves. If any1 can give me advice about how to go about doing this I will appreciate it.
    Press the wrist pins out and the rod will drop free.
    • akinswonder
      • Nov 2009
      • 177
      Thanx for the advice. I actually was able to remove one of the clips from one side of the wrist pins. Then I proceeded to push on the wrist pin but it won't budge.
      • AndrewBird
        The Mad Scientist
        • 11897
        That's why he said press it out, as in use a hydraulic press to get it out. It won't come out by hand. Try a local automotive machine shop.
        You can use a few sockets or tubes and a vice to push it out if you don't have anyone local that will do it.
        • akinswonder
          • Nov 2009
          • 177
          Gr8 Thanx.
