havent beenreally having any problems. I jsut cant get the head to seat correctly. It is like Wobbling, and not sitting down on the MLS head gasket, no matter how hard I push it down, or shift it, etc..
I have a MLS .071 Headgasket, so not sure how that affects anything. but I think it is a TINY bit oversize. Should I just clamp it down anyway. with the headstuds. I started clamping it and got to around 10 ft/lbs, when I Decided to back off and not try to really push it any more. The sleeves are almost flush with the gasket, due to its thickness, and springiness. : not sure if that means anything, so the head has a hard time seating on to the sleeves.
I know there are some brass rivets, not sure If I should clip them to ensure proper seating.
This is on an M10.
This is on an M10.
[/url]
