Is there an easy way to take off the plastic door sill piece that covers the interior weatherstripping? Mine can kind of slide but I dont want to force it off and break any clips that might be under it. I have a 318is (2 door), thanks in advance.
Door sill removal
Tags: None
Grab one end and pull it off. Some clips may break, but that's how they come out. They're only $0.75 each. -
slide it forward until it's free from the back clip. then slide it backwards over the top clipuntil it's free from the front clip, then slide forward till it's free from the second to back clip etc etc. This worked great for me. Still takes a bit of fidgeting though. Having the back seat out makes it alot easier too.Comment
I removed both of mine recently, with both front seats out. I managed to get both of them off only breaking one clip in the process. I just pulled the inside lip straight up rather smartly, and it came right off. All the clips remained, and then I used a flathead screwdriver and a pair of electrical pliers (crimpers, wire cutters, etc.) and slid them under the top rim of the clip and pulled up while prying with the pliers. I had to go slow and work them side to side, but it was effective. It can be done, just be patient. Of course, the clips gotta be cheap and you could order them ahead of time and skip all the drama. :D
[THE 501 club - Founding Member]Comment
can anyone hook me up with the part # for the strip and the clips... mine dun broke a long time ago...Comment
Those things were a royal bitch to get off. I actually ended up breaking the door sill all together on my parts car.
I finally figured out that the best way to get it off is to pry it off with a screw driver - just gotta know where each of the clips are. ;)- Sean HayesComment
Use 2 flathead screwdrivers. One on each side of a clip and do one clip at a time. :)
WillRIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
Welcome e30 (brilliantrot '90 325is) 12/23/06
DaveCN = Old Man
My signature picture was taken by ME! Not by anyone else!
Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.Comment
i've tried to pull mine off and got nowhere. probably didnt help that i pounded the strips down w/ a mallet :roll:
anyone know the p/n for the clips? also the door panel clips? i know a bunch are broken or will need replacement when i yank them both offJames
'88 M3Comment
