strange pistons found in M20b23
  • BavarianBimmer
    • 951
    can somebody clarify these pistons ?
    Those are not stock I think
    A.C.
    1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
    1997 E36 328iT
    1990 E30 325iT 24v SOLD
    1989 E30 325i 2.7i M-Technic II SOLD
  • Boots Walker
    • 36
    definitely not stock
    alpina perhaps?, i believe they modified the combustion chambers/pistons
    • BavarianBimmer
      • 951
      Alpina is possible
      But can you use this bottom-end with an stock head ?
      or is it worthless ?
      1997 E36 328iT
      • Jordan
        • 12916
        Don't know what those are, but the valve reliefs are overly huge.
        https://mtechniqueabs.com/
        • roadrage
          • Jun 2004
          • 54
          wow, that dome comes way into the head from the looks of that pic. Ive never seen a stock m20 and I know they are supposed to have fairly high compression, but that looks like a huge CR piston.
          • e30Matt
            • 5077
            Stock M20s have incredibly LOW compression (8.5:1)... probably why those pistons are in there.
            • modifiede30
              • 1208
              Definitely larger than stock. I'd suggest you find the head to see what was done to it. Might be better to just rebuild with the existing components rather than drop a stock 325 head on it.
              Driving is the only way to go faster....
              • bkelsey86
                • 1173
                323i"s are stock 9.8:1 compression ratio....the stock pistons only have one small relief on the drivers side for the valves.
                • modifiede30
                  • 1208
                  Let me know if you'd have any interest in selling those pistons and rods.
                  • rs4pro3
                    • 5808
                    The set of 323i pistons I had were domed just like that, but didn't have the huge valve reliefs, there domed just like the pre 5/85 525e 11:1 cr ratio eta eurp pistons just smaller diameter and won't fit in the 2.5/2.7 blocks
                    85 325e 2.7 ITB'd stroker
