No,
My car was doing the samething, I checked all the mounting points and found the tranny mounts had come lose.
Tighten then and all is good.
If all the mounts are tight, check the axle shafts for free movement in and out and your wheel bearings.
Also a worn guibo and center support bearing can cause the same feeling. If you have done a drive shaft change make sure the preload on the center support was done correctly.
