Transmission Tech Report
  • peerless
    • 285
    From: Quality & Service Engineer @ dealers.bmwna.com
    Subject: GM5 Transmission Delayed Shift Problem
    Vehicles:
    '03/'04(up to 11/03) E46 with M54 and GM5 Trans. 325iA, 325XiA, 330XiA, and from 03/03 325A/330A Coupe,Convertible, '03/04 (up to 12/03)E53 X5 3.0 with GM5 Trans.
    Situation:
    Excessively long delay (5-30 seconds) in gear engagement from Park to Drive on the first cold start. Problem occurs only once a day on the initial start-up.
    Cause:
    Unfavorable tolerances of forward clutch housing causing internal transmission pressure leak after overnight parking.
    Service Fix:
    Replacement of defective Transmission with updated unit.
    I heard someone complain of this problem,
    so there you are. Call your local dealer and get your new transmission.
    Robert
    85' 325e
  • Charlie
    kid tested, administrator approved
    • 6686
    Um..
    I don't think BMW produced too many '03 & early '04 Model year e30's.
    For some reason, I imagine bringing a 20 year old slushbox car into the dealer and asking for a new tranny would probably not produce the desired results.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
    • peerless
      • 285
      Charlie,
      Although this post maybe for older E30 owners, some of those owners may also
      own a newer BMW as well. You will also notice that all years and models affected
      where listed.
      I was just being a nice guy and forwarding General BMW Tech information to the communityat large. If you are against that I am sorry for you as a moderator. As the larger BMW community may find it useful.
      I will refrain from making further posts regarding factory TSB's (Technical Service Bulletins)
      Respectfully,
      Robert
      85' 325e
      Factory BMW Parts Technician
      • Charlie
        • 6686
        Originally posted by peerless
        Charlie,
        where listed.
        Respectfully,
        Robert
        85' 325e
        I've got no problems with TSB's being posted, I just don't see any years of e30's or any other car that shares the e30 tranny being posted.
        -Charlie
        FYYFF
        • peerless
          • 285
          To be honest I had never noticed that this was an E30 Only Bulltetin Board until you
          posted your response. My bad for that. But nontheless I still hope that people here will
          appreciate the information regardless.
          My bad for being testy, just trying to give out information that might prove useful to someone.
          Robert
          85' 325e
          • Rob
            • 8166
            post this on DTMpower.net, there's a ton of e46 guys one there
            BEERTECH
            • James Crivellone
              Head Janitor
              • 6305
              my e30 auto tranny works fine, even after me beating the hell out of it and 197,000 miles
              then again its ZF and not GM ;)
