Gauge cluster lights dim
  • roadrage
    • Jun 2004
    • 54
    I tried searching, but couldnt find anything that helped.
    My gauges are very very dim, but it doesnt appear that any bulbs are burned out. Every gauge is lit...but so dim i can barely make out the gauges. Any help is appreciated.
  • aaron_silva
    • 1785
    Turn your headlight switch. It controls the brightness of the gauge cluster.
    Aaron
    • NC325iC
      • Mar 2004
      • 6565
      :stupid: bet you feel like an idiot now dont you
      • DanGillan
        • Mar 2004
        • 4061
        clockwise is brighter
        Dan
        • roadrage
          • Jun 2004
          • 54
          I know there are some real dumbasses on the net, but im generally not one of them :nice:
          The knob is set as bright as it can go.
          • Jand3rson
            • 37587
            Replace the bulbs in the cluster, they are pretty cheap.
            • roadrage
              • Jun 2004
              • 54
              They get dim? I didnt think a bulb could just get that dim..unless it burnt out.
              • e30Matt
                • 5077
                Perhaps the rheostat in the headlight switch is going bad... try another headlight switch. They can be had for cheap from a junkyard.
                • DarkWing6
                  • Apr 2004
                  • 7144
                  Don't you gotta pull the dash to do that?
                  • DEV0 E30
                    • Oct 2004
                    • 8891
                    Hit the dash in the center some. Our cars love to do funny things if there is something loose.
                    • Speed25
                      • 39
                      I had the same problem on my previous e30. The instrument cluster is pretty easy to get out and play with. The bulbs are obvious to change. Here's what NOT to do: I found the same size bulbs with slightly higher wattage (seems like it was 3w replaced with 5w, but I'm not sure). Anyway, it looked GREAT when I put them in. Right up until they melted the orange lens covers...
