For a while now my blower motor hasn't worked. Found out that one of the cages had exploded, so I took the mint condition one out of my 84 325e and put it in my 88 325is. Measured the one good cage on my busted motor and it was the same size as the one out of the 325e.
I put it in and it works fine on speeds 1 and 2, but on 3 and 4 the cage starts grinding/rubbing on the black housing. There's only like 1mm of space between the cage and the housing on the driver's side, but at least 3mm on the passenger's side. If I pull the motor towards the passenger side, the noise goes away. I put it in exactly like the original one. wtf? :(
Matt
Matt
