So I'm getting ready to do the brakes on my 318ic. The fronts are in need of replacement (pads and rotors), but the rears are in good shape, about 50% left on the stock pads and rotors. I'm going to get ATE PowerDiscs, but need suggestions on pads. I was thinking about Metal Masters but didn't know if I should mix-n-match with the rears staying stock. It would seem to be a waste to replace the rears with new pads and rotors. My car is used primarily for the daily commute, but I would like to take it to the the auocross from time to time. Some people have suggested that Mintex, Pagid OEM or PBR Deluxe pads should also be fine. Any thoughts on this?
Brakes...thoughts and suggestions.
if its the daily commute, the stock rear stuff will be fine as long as its in good shape. For the front, you've chosen rotors; pads, any street+ pad should work well, and by street+ i mean a pad thats a little more aggressive than OEM stuff. I'm going with axxis ultimates, the ITR guys love them. Also consider EBC greens and Hawk HPSBEERTECH
Cross drilled rotors crack and can put you in a dangerous situation if you are on the track or in the act of some adrenalin filled runs. I have run slotted in the past and running them now.I will never buy drilled rotors since. True cross drilled rotors will not crack on you but will cost you a hefty amount. I dunno if they even make true cross drilled rotors for the e30.
I run ATE slotted rotors with Metalmasters, and they are fine around town, except for the spongey feel of the soft pads. During slightly spirited driving, they do pretty good, with precise braking that has moderate feel. Full-out, on the limit driving....they are miserable. They fade very quickly, and don't do a good enough job of slowing the car.
This is my experience----though I have about 2x the HP of a 318, and I realize I need larger brakes, which I will be doing in the future.
I would recommend stock or ATE slotted rotors with EBC Green pads. I ran that combo on my 318 with the 4cyl and had no problems except for heavy brake dust and poor initial bite. However, once warmed up slightly.....they leave you hanging in the seatbelt coming into corners. :)
Originally posted by Stu McI run ATE slotted rotors with Metalmasters, and they are fine around town, except for the spongey feel of the soft pads.
trent
Originally posted by e9nineOriginally posted by Stu McI run ATE slotted rotors with Metalmasters, and they are fine around town, except for the spongey feel of the soft pads.
Originally posted by trentMetal Mastesr are junk pads -- total 80s technology. Get into the 00s and get some new pads; EBC Green, Hawk HPS/+, R4S...
Originally posted by e9nineOriginally posted by trentMetal Mastesr are junk pads -- total 80s technology. Get into the 00s and get some new pads; EBC Green, Hawk HPS/+, R4S...
trent
Originally posted by mgoldOriginally posted by e9nineOriginally posted by trentMetal Mastesr are junk pads -- total 80s technology. Get into the 00s and get some new pads; EBC Green, Hawk HPS/+, R4S...
Originally posted by JarvisI got ATE PowerDiscs with the MetalMaster pads this summer. I think it's a good combo - they work great and I haven't had any problems with the MetalMasters making tons of shitty dust on my wheels.Brandon
