functional MAF conversion !
  • mspiegle
    • 1026
    well, its done and works.
    While driving, the AFRs stayed between 14.0 and 14.4, acceptable for now. I took it up to 5500rpm with the AFR being about 14.4. I would assume it to get a little higher @ redline... but i won't be able to fix that too easilly until i put the larger (19lb) injectors in. I would like to keep it between 13 and 13.5.
    Basically, i used a MAF from a '98 328i. I wired it up, and was able to start the first time without trouble. The voltages @ idle were only slightly off, easy to compensate w/ the SMT6.
    i made some more adjustments and went on my way. no problems at part throttle, idle, or WOT. The butt dyno DID register something this time. I couldn't feel a difference with the 535i AFM. So... to me that counts for alot. I hope to get a gtech competition meter soon and do some before/after testing to see if i got much.
    response was definately MUCH better. Also, seemed to have a little more juice @ low rpms, but not much. I'm very pleased thus far... but still have MUCH to do.
    Michael Spiegle
    '01 Ford Escape / Daily Driver
    '99 M3 / Track Car
    '87 325is bronzit / wtf car
    '06 Daytona Triumph 675 / Daily Rider
  • Charlie
    kid tested, administrator approved
    • 6686
    Sweet, take pics and work on a partial writeup.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
    • Rob
      • 8166
      sweet, on what motor setup?
      BEERTECH
      • mspiegle
        • 1026
        fully stock m20 (no chips)
        Michael Spiegle
        '99 M3 / Track Car
        • Jonathan M3
          • 1837
          Sweetness, a MAF was my next planned mod for my engine and yours sounds very interesting. :)
          '05 E46 M3 Imolarot/Cinnamon - CURRENT
          '98 E36 M3 Estorilblau/Dove - SOLD
          '90 E30 M3 Brilliantrot/Black - SOLD
          SRS BSNS Motorsports - 24hrs of LeMons Racer
          • mspiegle
            • 1026
            my maf was $50. Add to the cost of gunni's SMT6, and you've got a cheap mod. Not only can you have your MAF, you can have adjustments too =)
            and don't forget how much split second's setup costs...
            go on, buy one! you know you wanna...
            BMW, ECU, VEMS, AmpEfi, MaxxEcu, Bosch, motorsport, PNPEcu, mapping, tuning, calibration, Cosworth, Pectel, racing, Aston Martin, Vantage, Vulcan, Renault, Megane, VW, Audi
            And yes, i am advertising for gunni. He helped me out alot.
            Michael Spiegle
            '99 M3 / Track Car
            • rs4pro3
              • 5808
              Very nice to hear. I've been trying to tell people that all they need is a cheap MAf and a singla calibration device but no one ever followed threw. Let me guese did you need to lower the single at IDle and rais it at WOT? that's what my 325i MAf would need to work with the 325i. As with it wired straight in I was running full rich at idle and off the scale lean at WOT. In between it was about perfect and hads lot of power till it leaned out. Does the SMT-6 pake the adjustments at idle, partial and WOT easy?
              85 325e 2.7 ITB'd stroker
              • mspiegle
                • 1026
                Actually, with mine i had to raise the signal at idle but WOT was fine for the most part. I am using a Seimens unit, you may be using a Bosch unit.
                I've been waiting to get my hands on an SMT6 unit because I knew i could make it work with these mods... And you're right, nobody believed. Got comments like "it wont work" and "you're going to blow up your car" (no offense guys), but you gotta experiment if you want to learn.
                And yes, the SMT6 is capable of making on-the-fly adjustments to any combination of throttle position and RPM, it is as easy as putting a higher number or a lower number into the mapping. I would highly suggest you guys get one of these from gunni.
                Michael Spiegle
                '99 M3 / Track Car
                • rs4pro3
                  • 5808
                  Ya I was trying the Bosch unit.
                  • spud814
                    • 287
                    hey mspiegle,
                    Could u do a small write up on this and have a mod post it in the tech section so we all have this info at our finger tips. Also the difference in performance u felt and prices u paid for the whole setup woudl be nice too so we could all know how much u save versus the split second setup. thanks mspiegle.
                    • UNHCLL
                      • 8789
                      You got the 2nd one pretty quick. Glad to see you got it all worked out.
                      Chris
                      ~hoping the comment in the other thread was legit about blowing up the first MAF.
                      Below the radar...
                      • mspiegle
                        • 1026
                        actually, i'm using the same MAF. When I thought my diagram might be wrong, i assumed that i had already blown the unit. I went and tried every combination of pins just to see if the MAF would give out any signal, again assuming that if the MAF wasn't blown before, it would be blown now. I didn't realize that if you don't pass air over the sensor, it wont register much of anything.
                        With the AFM, even if the door wasn't open and there was no air passing through, there was a slight voltage. With the MAF there wasn't really anything. I found the correct wiring diagram, wired it up, and noticed that it read 16 millivolts. This was such a small voltage, i assumed it was because the unit was busted. I blew into the MAF, and it registered about .9V. Right then, i wired everything up and started my car.
                        Good thing these parts are durable, i'm suprised... i hooked the thing up backwards and wrong in several different ways. Still worked!
                        Michael Spiegle
                        '99 M3 / Track Car
                        • UNHCLL
                          • 8789
                          Try Try Try Again. Good philosophy.
                          Below the radar...
                          • gstuning
                            • 833
                            Excellent to hear, I love it when things I have said for along time are correct,
                            I said it first on the BEN and notbody bought in on it, but it is true,
                            MAF conversions don“t have to cost an arm and a leg,
                            Micheal you have done an awsome job
                            Gunni
                            @ Prodrive / Aston Martin Racing
                            • skat 325is
                              • 296
                              Whoo i think i got more excited when u told me over msn than you when u got it to work.
                              I'll be ready to experiment on mine tommorow, cant wait.
