for some reason my wiper linkage keeps popping off the drive arm from the motor.
not the connection directly under the wiper motor, its doing it on the side that is directly under the drivers side cowl that has the metal coupling and little rubber bushing.
i replaced the bushing (#6 in this diagram)
http://www.realoem.com/bmw/showparts...85&hg=61&fg=45
however it seems to work for about 3 times then pops off again on the upswing side of the stroke. i couldn't find what type of grease to use, i would assume wheel bearing grease or similar. is this needed to keep it stuck or can the actual metal busing part wear out as well?
