how do you tell is its 325i or 325e block?
  • bmwe3
    • 118
    posting this for a friend i also would like to know. He bought a 87 bmw 325is some idiot put a 2.7eta head and intake manifold on it how can i tell if its a 2.5 bottom end or 2.7 without taking the motor apart? Does it make a big hp difference if its a 2.7 block & 2.5 top end?
    His old car is for sale 1988 325is 127k 5spd hit rear driver quarter panel after spending close to a $800 in the car he only had it for 2 weeks dam jap racer trying to drift in a piece of crap trueno. The car is basically a parts car still runs and drives great make offer in southern california.
    thanks alot
  • Jordan
    • 12916
    the block will have numbers cast on it. Also near the oil pump drive, there is a VIN number on the block, see if it matches the car.
    https://mtechniqueabs.com/
    • bmwe3
      • 118
      i see you post answers all the time to peoples questions thanks alot man you know your e30's
      • Super Eta
        • 1884
        Where is the vin?
        When you say VIN do you mean the VIN like as in the one on the dashboard but instead on the block because all i find is serial numbers.
        I looked on my 1986 Eta block and my 325i block
        • DaN
          • 1265
          You sure it is actually a 325is?
          It could be an eta with a different badge.
          What does the sticker inside the driver's door say?
          • bmwe3
            • 118
            its a IS for sure the driver strut tower says engine family m20b25 ive had a 88 325is that was a factory 2.7. on the 87 below the alternator on the block its stamped 2597866 does this mean its a 2.5? the vin number are put on by stickers on the block but has been washed off this car.
            • Super Eta
              • 1884
              Stickers! well that explains it.
              No way in heck would sticker be on an engine block after more then 12 years or less
              • DaN
                • 1265
                Yes, but what does the sticker say inside the driver's door say?
                I wasn't aware that they made a 325is with a 2.7, can anyone else confirm this?
                • bmwe3
                  • 118
                  on the door it says 325 I/IS .yea i didnt believe it either i bought a 1988 325is it had the I intake manifold,tb but the head was stamped 2.7 and the engine family was m2b27 it needed the cam replaced since number 6 exhaust cam lobe was ground down almost a 1/8 inch the dealer didnt believe me when i went to buy head gasket set either til he saw the car. i still have te head off the car. same casting numbers as a E head.
