will e30 m3 flywheel work on my m20?
  • DanGillan
    • Mar 2004
    • 4061
    as the topic says, i have a spare flywheel i want to get lightened, its from an e30 m3 though, will it bolt up to my m20 and getrag 260? i believe it's the same except the magnets in it or whatever. anyone know? thanks,
    Dan
    Dan
  • uofom3
    • Jan 2004
    • 5392
    i'm not positive about this at all.. but i don't think so. The m3 setup is different.... generally speaking.. if its for an s14 engine, that's about all it will work on/with... very specific parts
    PNW Crew
    90 m3
    06 m5
    • DanGillan
      • Mar 2004
      • 4061
      i was told it should work though, wanted to check here though, anyone know for sure?
      Dan
      • e30Matt
        • 5077
        Going by the ETK, no... but that doesn't speak for the experimenters out there.
        • nitro325is
          • 495
          Re: will e30 m3 flywheel work on my m20?
          Dan
          No it will not work! Dont even try it.I had an experience with this about a year ago when I ordered my Alu flywheel for my m20 b25 but they sent one for an s14.I kept removing and reinstalling everything 4 times before I figured out what was wrong.It is the exact same diameter but it is a about 1/4 inch thicker thus not enabling clutch to fully disengage.Also the # of teeth are different/different size so they will start the car but keep hitting the starter.Also the S14 has a trigger on the fly as well.
