Paint to use on brake rotors centers?
  • rwh11385
    lance_entities
    • 18403
    I'm guessing high temp shit. I just remembered I'd be a good idea to hit up those centers with some paint to avoid rust and keep the wheels from sticking to the brakes, etc.
    What paint? (and should I hit up the inside portion as well, to keep it from sticking to the hub, or just use something like anti-sieze on the hub face?)
  • 87 325iS
    • Jun 2004
    • 277
    I used VHT Brake Caliper, Drum & Rotor paint. Worked real well.
    Amber Fire Pearlcoat 2000 Dodge Dakota R/T
    Schwarz 1991 BMW 535i [Daily Driver]
    Dark Currant Pearl 1996 Acura Integra GS-R [For Sale]
    Orientblau Metallic 1994 BMW 740i [Sold]
    Alpinweiss 1987 BMW 325iS [Junked]
    • kowalski
      • Jan 2005
      • 1791
      engine enamle will work anything higher temp rating then that iwll also work. also base/clear with self etching primer will work too. or the caliper paint but make sure to clean off with a alchahole based degreaser first so that it evaporates after.
      • kowalski
        • Jan 2005
        • 1791
        engine enamle will work anything higher temp rating then that iwll also work. also base/clear with self etching primer will work too. or the caliper paint but make sure to clean off with a alchahole based degreaser first so that it evaporates after. I.e. brake cleaner
        • Jordan
          • 12916
          I used VHT brake paint on my rotors. This was back in Nov 04. Still every bit as good looking, if not for some brake dust in the vents.
          https://mtechniqueabs.com/
          • rwh11385
            lance_entities
            • 18403
            Mmmm, tasty Jordan. Did you cover the vents to avoid painting down them, or does it matter?
            I'd imagine wrapping around them would simple if yes.
            • Jordan
              • 12916
              I sprayed all down inside the vents... helps prevent unsightly rust.
              and truth be told, I didn't waste time masking the friction surface. I sprayed the rotor as needed. Obviously I didn't get any more on the friction surface then I needed to, but no harm is done.
              The paint comes off on the first couple stops, and after a day or so will be completely gone.
              • Jand3rson
                • 37587
                Good to know about painting down in the vents, I was wondering about that for when I do mine.
                • rwh11385
                  lance_entities
                  • 18403
                  Thanks Jordan!
                  (btw, I'm so painting my old rotors gold (or green/pink) and mounting them to piss everyone off) Then turn them to get them clean again.
                  • KDZROK
                    • Aug 2004
                    • 759
                    Should I do this to mine? There is ALL KINDS of rust in and around my calipers...my rotors are pretty ugly too.
                    Maybe it is just time for new ones?
                    *sigh* there is just so much that needs to be done to my car.
                    • nefarious7907
                      • Jan 2005
                      • 1170
                      This link you can create your own decals and they have decals specific to bake calipers and I am ordering some BMW decals for my rotors. The thing is I dont know about whether or not to paint my calipers black or red, do you guys and girls think that red is too ricey for a BMW?
                      http://www.cardomain.com/ride/657387
                      • Jordan
                        • 12916
                        That is horrible.
                        • KDZROK
                          • Aug 2004
                          • 759
                          I would want to paint mine black, to match my car...
                          Calipers look SOO hot in the body color!!
                          Rob, you should go for what's in that pink rattle can!
                          • rwh11385
                            lance_entities
                            • 18403
                            Body color calipers for me = no no, red stock calipers = Boo. But my rotors are going black just because that's all that was available tonight at 10:30 ;)
                            Kristin, you should go with PINK, it'd match your INTERIOR color. :rofl:
                            • draculia
                              • Oct 2004
                              • 36
                              vht caliper paint is just about the best bang for the buck from a rattle can. i really love g2 caliper paint. 1 set was enough for me to do all 4 calipers and rotors. i've used this stuff on 3 different cars. when i clean things up the paint looks just like it did when i first did it 4 years ago on my dsm. i was waiting for the caliper rebuild kits when i took the pic, if you're wondering why there's a glove zip-tied to the line.
                              before anyone jumps to the conclusion that the rotors are mounted on the wrong side, they are straight vaned.
