On the 87 325is i've chased down to a .75mm wire that reads .6 ohms to ground with everything turned off. This shorted wire starts from fuse circuit 10 which has three wires all of .50mm branching out from it, two of the three are clear. The wiring harness branches out from the drivers door across the front of the drivers seat towards the center console, this branch has the heated seat ciicuit in it also. This harness branch group has Brown/Green .75mm, Brown/White .75mm both for the heated seat not used. With this same branch also a Brown/White .75mm, Brown/White .50mm, Brown/Green .50mm, Blue/White .75mm, Blue/Gray .50mm, Gray/Red .50mm and a Green/White.75mm.
This Green/White .75mm what does it feed heading towards the hump and console as it's the gounded out wire? If I flash the circuit i'll read 26 amps plus the defrost fan will run if switched on at normal rpms. I've lost all insturments in the cluster no gauges work.
The Green/White wire is shorted to ground, any tips or clues trouble shooting this problem? Thanks in advance.
