I'm trying to change injectors on a 90 325i. All the how-to articles and the Bentley make it sound so easy. I knew I was in trouble when I raised the hood and couldn't see 95% of the stuff I needed to wrench on.
After two hours of swearing, sweating, and squinting, I have gotten as far as disconnecting the battery and two electrical connections. That's it. I've printed out the instructions from Dave's site, the Pelican site, and I have the Bentley. I can't even see how to get that plastic cover off the electrical injector connections. I can't see any fuel line at the rear of the fuel rail that I'm supposed to disconnect either. Lord knows how I'll disconnect and connect that electrical connection under the intake manifold on the driver's side. I can barely touch it with my fingertip much less grab hold of it.
First things first, any hints on how to get the plastic cover off the injector connectors?
