does this need to be reset once it goes off?
brake warning light
brake warning light
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Tags: None -
Re: brake warning light
which brake warning light? the brake fluid level? brake pads? brake lights? in any case, these warning lights go off when you correct the problem. no reset necessary.Originally posted by ///M42 sportdoes this need to be reset once it goes off? -
Originally posted by e30 dudewhich brake warning light? the brake fluid level? brake pads? brake lights? in any case, these warning lights go off when you correct the problem. no reset necessary.Originally posted by ///M42 sportdoes this need to be reset once it goes off?
well, assuming that you change the sensors if its brake liningComment
I meant the brake lining light on the dashboard. :)Renting my rear wheel bearing tool kit. SIR
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
on newer cars that indicates a difference in brake fluid pressure.... pointing to a bad mastercyl, or a bad proportioning valve.... could be low brake fluid as well....
at least i thinkComment
