Question on fuel pumps
    My car has 2 fuel pumps but I don't have the connector for the external one in my wiring loom. Do you know if I will still get fuel if the external fuel pump does not get power? Or do I have to actually bypass it. I upgraded the in-tank one to a high flow version so I don't actually need the external one now.
    90 E30 S50B30
    http://www.fquick.com/roadhazard/
    If you replaced the in-tank transfer pump with one from a late production 318is, you can remove the external high pressure pump.
      Right. The question is that if leave the external one intact but unplugged, is it going to block the fuel flow?
      90 E30 S50B30
        Yes
