Strange problem with my E30!
  • 2FST2C
    • 25
    I drive it home from work on friday, i park it, shut off the engine but the AC is still blowing...weird...i just turned it off manually and went inside. The car was sitting until sunday evening i tried to start it but it was completely dead...no lights, no crank, nothing. Any ideas on how the AC just decided to stay on even tho i turned everything off and drained the battery?
    any input greatly appreciated!
  • jeffw
    • 1087
    I put in an electric fan on my early model and have the same problem from time to time my blower motor and my radiator fan stay on. I haven't figured out what it is yet
      A stuck relay, bad ignition switch, or shorted wires are the likely candidates.
      • StereoInstaller1
        GAS
        • 22679
        Lawn gnomes messing with your stuff is an option too
        Closing SOON!
        Thanks for 10 years of fun!
        • 2FST2C
          • 25
          i popped the hood and noticed the fuse box was real hott too. so i think its definitely something with a relay, fuse or wiring. i was just hoping maybe someone had the same problem and a solution?
            You'll just have to trouble shoot the circuits and see where the problem is.
            • 3bvert
              • 1032
              same issue, mine was ignition switch
              no cash at time, sprayed pb blaster in it, let it sit, turned it on and off a bunch of times, no problem since, lucky I guess
              logically that should not have fixed it, that would only fix the pins etc in the lock, but hey, it worked
              • 2FST2C
                • 25
                your ignition switch affected your AC staying on?
                  If the ignition switch isn't turning off, it would affect the A/C system. But that should be obvious as the cluster warning lights would on.
                  • 2FST2C
                    • 25
                    yeah see thats not the issue then because when i took my key out everything turned off except the ac...so i did it manually but i guess that didnt do it... the relay powering the ac must of been stuck and still running
                    • payney8
                      • Jun 2007
                      • 899
                      sounds like the relay is sticking or you have a shorted wire check your ac power
                      • 2FST2C
                        • 25
                        it was a stuck relay, i bought a new one cost me $10
