Super ETA Head with I pistons?
  • ZiMMie
    • Jun 2004
    • 968
    will be benificial to person with an eta Block? will it make any power? would not mind sellin them as a combo.
    www.stancefactory.com
  • rs4pro3
    • 5808
    yes they would be, it's a good budget stock option, and no shaving of the pistons required like with i pistons.
    85 325e 2.7 ITB'd stroker
    • ZiMMie
      • Jun 2004
      • 968
      thanx. Now who would be intrested in this. ill let go for very very cheap. 8)
      • Rigmaster
        • 3464
        the super eta head is nothing more than an M20 325i head, but with different valve springs + a milder cam. The best thing about the super eta engine is the pistons- if you want to build a cheap + easy 2.7l stroker, you use the super eta pistons with an "i" head (or install "i" cam + valve springs in the super eta head), use the "i" intake, injectors, ECU, etc, etc.
        Do a search here or on Roadfly or any of the other E30 forums and you'll see alot of chatter about this topic
        Bret.
        • ZiMMie
          • Jun 2004
          • 968
          thanx but i already knew that jst needed to know if the my current I pistons and the super eta worth somethin.
          • pogiboy9
            • 475
            Hmmm planning to do the ETA Bottom crank, with I shortblock conversion. will that help me... if so ... give me holler how much $$$ pm me i'm in california.
            http://www.decal-spec.com
            • ZiMMie
              • Jun 2004
              • 968
              well am keepin the buttom end am jst sellin the Heads with the I Pistons from my other block.
