Blinker problem
    Blinker problem
    My left blinker blinks at a fast rate as if one of the bulbs are out. None of them are. When I turn on the emergency blinkers they blink at a normal rate. Is there a relay perhaps that isnt working right? Where should I begin.. tia -dan
    Ive got the same problem. Maybe the relay is bad, idk.
      turn signal relay is under the lower steering column cover.
      The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
        I have the exact same problem. Always assumed my socket was bad.
        I took apart my bumper almost a year ago now and the problem went away. It just came back. :(
        Sure fire fix anyone?
        I just hate everyone.
        No need for discretion.
          my connector was just dirty and a little loose when this happened to me, popped it off,
          cleaned it, popped it back in and bam! no problems since.
            This happened to me but not on my e30 it was on my LS just changed the bulb and went away.
            r3v does not fuck around. First you get banned, then they shoot you
              Check the tightness of the light assembly in the trunk. It should be pointing to "zu".
              Me: "I can't wait to redline my car!"
              Mark: "Didn't you just break a rocker arm?"
              Me: "Yeah, I don't think I've learned my lesson."
              Mark: "You never will."
