Coolant smell when heater is on?
  • joecoolinatl
    • Sep 2004
    • 121
    is the heater core going bad?
    or could this be because the recall was never done on it?
    Present:
    1984 633csi
    1985 635csi
    Past:
    1991 318i / 1987 325e / 1988 325is / 1986 325i / 1985 535i
  • Jordan
    • 12916
    Heater core, valve, or piping. Certainly in the interior.
    Have fun.
    https://mtechniqueabs.com/
    • joecoolinatl
      • Sep 2004
      • 121
      called nalley bmw here in atlanta, asked them if the recall was done on the heater core, they said no, and asked me when i wanted to bring it in, so taking the 87 in on saturday wooho they said it should only take an hour.
      Present:
      1984 633csi
      1985 635csi
      Past:
      • James Crivellone
        Head Janitor
        • 6305
        Have fun.
        Yep, either one of those.
        I just replaced my heater core and valve, have fun, and prepare to have a small waterfall inside your footwell when you get it out
        • pogiboy9
          • 475
          well to prevent that waterfall can't he just drain the coolant?....ooh question ..... the recall thing ? whats that about..
          http://www.decal-spec.com
          • ZiMMie
            • Jun 2004
            • 968
            No think about it. unless u release the all the pressure from the collant hose even that am not sure. cause the is always some sort of coolant in the heater core.
            www.stancefactory.com
            • Jordan
              • 12916
              Draining the coolant makes less of a spill, but the heater core and valve do not drain. They will retain any coolant they have in them.
              • nefarious7907
                • Jan 2005
                • 1170
                i had a that smell in my car for a while, but then I noticed that I didnt have a blower motor cover? I still have idea where it went it up and vanished.
                http://www.cardomain.com/ride/657387
                • Mike 91 318ic
                  • Jun 2004
                  • 429
                  All they're going to do is install a bypass valve and install a new rad cap which is why it'll only take an hour. They're not going to replace the heater core or valve which is your problem.
                  M
