VAC Floor Mount Dimensions
  • MSFIT
    • 81
    Not sure what forum to dump this in, mod's please move if wrong.
    I'm looking for dimensions from the vac floor mounts so I can bang out something similar.
    There's a lot of dimensions to it, so it'd probably be best if I could find someone in San Jose area with a set out of their car =P in the car works too.
    The simplest mount for a race seat is made with pieces of 1-1/2x1/8" strap and 1" square tubing. Look at the seat bases and the mounting points and a solution should suggest itself.
    Hint: run the tubing across the car and use 3" tabs to the car mounting points welded on perpendicular to the tubing. Use long straps running fore and aft for the seat base attachment.
