help please
  • mentaleeill
    • 850
    help please
    my 88 325e automatic just started to misfire. when idling it pops through the exhaust consistently like a pattern. i replaced plugs, cap, rotor, fuel filter, and airfilter all about 4000 miles ago, and also at the same tie put an i t.b. and intake manifold on it. what could cause this now?
  • pogiboy9
    • 475
    misfire? ... check your wires. and plugs
    http://www.decal-spec.com
    • almost_goth
      • Dec 2004
      • 23
      You could try throwing a can of SeaFoam at it and see if it clears up.
      • mentaleeill
        • 850
        ok, i checked the plugs today and found that 1-5 are in perfect shape, but 6 is black with a carbon buildup. also did a compression check and that was perfect. what could make #6 gum up with carbon? injector, bad plug? i tested to make sure 6 was firing and it is.
        • kowalski
          • Jan 2005
          • 1791
          check the gap
          • mentaleeill
            • 850
            gap is right on the money. ran sea foam through it today and it's still doing it. any ideas?
            • Jordan
              • 12912
              Try naming your thread. Try something that relates to your question. It gets alot more views.
              "Help please" is a sure fire way to get banned.
              https://mtechniqueabs.com/
              • kowalski
                • Jan 2005
                • 1791
                did you time it after all of this? your timing is probably off
                • mentaleeill
                  • 850
                  banned for what? i need help, which is why i chose that title, didn't think there was anything wrong with that.
                  • Jordan
                    • 12912
                    You've got 5 minutes to change the thread title to something appropriate.
                    • Dave
                      E30 RAT
                      • 11675
                      You made me waste my time coming here. If you put it in the thread title, we can tell whether or not it is something we can help with.
                      Current Cars
                      2014 M235i
                      2009 R56 Cooper S
                      1998 M3
                      1997 M3
                      • Charlie
                        kid tested, administrator approved
                        • 6686
                        I'm playing good cop and added a description to the secondary subject line, it's perfect, utilize it.
                        Compare the plugs in the bentley vs your misfiring plug, is it oily or just fouled?
                        Check valves, adjust if necessary, and check your plug wires. Get ready to cough up cash since they're a pretty decent penny for good ones (~180).
                        -Charlie
                        Swing wild, brake later, don't apologize.
                        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                        FYYFF
