torque spec
    torque spec
    Just got done doing my trans output flange seal and cant seem to find the torque spec for the nut. Does anyonw know it or know were i can find it?
    thanks
    The output flange is sealed with a high strength stud locker on both the
    splines and threads.
    The manual recommends: Locktite 270 or Hylogrip or Curil K-2
    Locktite 270 has been replaced by 2701 (or #27040)
    BMW recommends Loctite 242 for newer transmissions, but that may not be
    correct for the Getrag 260.
    Apply the sealant to the splines on the flange only, not the shaft
    splines. Slide the flange on, and apply sealant to the bearing surface
    of the collar nut. Tighten in two rounds: tighten to 125 ftlb, loosen
    1/4 to 1/2 a turn, then tighten to 90 ftlb. This assures that the
    flange is fully seated on the output shaft, not on trapped sealant.
