Oil Pan Gasket sealant? plz help
  • crazy_hotrodder
    • Sep 2004
    • 14
    Is it necessary on an m20 oil pan? I didn't see an answer on search so figured i would just ask. thanks
  • BahnE30
    • 1050
    slather a little orange RTV on there and your good to go, not necessary but why not
    • pogiboy9
      • 475
      Yup best way to go usually, unless you plan to T O T A L L Y clean off the old gasket which is a pain, cause if you don't scrape and clean it good just gonna leak. I do it for the water pump too, on mine and mostly all cars i work on.
      http://www.decal-spec.com
      • cthulu703
        • Oct 2004
        • 288
        I scraped the surface, then used Halomar HPF to seal. 3 months, no leaks.
        • formula driver
          • 2263
          Silicon sealent and 12 months later..... not a drop of oil has leaked.
