318is Hestitation.. check engine.. Adapter lead?
  • jrobie79
    • Mar 2006
    • 2526
    check out post 6
    1991 318i ---- 308K - retired
    • Highway1
      • Jan 2009
      • 773
      Originally posted by jlevie
      The first thing to do would be to run the fuel system tests in the Bentley manual.
      I have no Bentley :(. does anyone know how to test fuel pressure?
      ..and it's not the "hot start" problem. my car starts any idles just fine. the hesitation is when it is cold or hot, no difference
      • Danny
        • 14216
        Your AFM is bad. I would put money on it. Try cleaning that bitch out and see if it helps.
        • Highway1
          • Jan 2009
          • 773
          yessir
          • Highway1
            • Jan 2009
            • 773
            well... that was a waste of 7 bucks.
            • jrobie79
              • Mar 2006
              • 2526
              the hot start problem wasnt a hot start problem with mine, it happened all the time, idle, taking off from a stop, had to rev it up to like 3K to get it to go anywhere....took me forever to figure it out then one day i saw that thread and disconnected that piece, and boom it was fine.
              did you check the TPS? the screws that held mine on were rusted to shit so it was kinda loose, i replaced then with some stainless steel hex bolts and it was tight and helped out in my case.
              kinda looks like you did the "clean the mess up under the intake mod" on the m42, maybe the line coming from the ICV is collapsing under the vaccuum it creates, think thats only an idle problem though, couldnt help to check it out, what i did was put a straight line hard plastic coupler right in the middle to strengthen the hose. just my two cents, hope you figure it out.
              • Quadrajet
                • Jul 2008
                • 1278
                Had the same problem with a 318is I recently acquired. Pulled plugs, which were fine. Threw on a set of wires I had laying around. Did the trick. If you can locate a spare set of known good sparkplug wires, it's fairly quick to check to make.
                • X_WizarD_X
                  • Jul 2005
                  • 99
                  bad engine temperature sensor
                  It's the rear sensor.
                  06 ENGINE COOLANT TEMP SENSOR 1-POL 1 12621710512
                  Mine was doing the same thing.
                  The Keystone Killers: for the Commonwealth!
                  Member #18 of M42Club.com
                  1991 318is Diamantschwarz Black
                  1992 850i Calypso Red
                  • Highway1
                    • Jan 2009
                    • 773
                    Fixed! It turned out to be the fuel pump. The hose that connected the pump to the carrier inside the tank some how slipped halfway off. I put in a longer hose so now it will be impossible for it to slip off again.
                    Thanks for all the help
                    • jrobie79
                      • Mar 2006
                      • 2526
                      Nice, might have to check that on mine now
                      • sonnyqm3
                        • Sep 2009
                        • 1144
                        hmmm I got to check this on my 318is as well. I did all the maintenance on the car but will check this as well. I love the info ppl give on this forum.. thanks..
                        • Highway1
                          • Jan 2009
                          • 773
                          Yeah i think this only applies to aftermarket fuel pumps like Walbro and Tre. the oem pump has a plastic/metal piece that wedges in and shouldn't come apart.
