Hey guys,
I don't know how to desribe it, it's quite subtle but it's enough to notice that something is weird. The engine tone is clear and crisp up until 3000RPM when it sounds as if something were coming in contact with a spinning object, like say if you turned on a fan and then you hold a piece of paper out to make contact with the blades while its spinning. Is this the timing chain tensioner? Is it something that I should be extremely worried about? It's not very distinct as of now, but I don't want it to get any worse and have an effect on my engine.
From the description of past problems with the tensioner, it sounds as if it may be that, but it's not a distinct "high pitched" sound, it just sounds like all of a sudden, a piece of paper is being held out in the path of a rotating object or something. The tone of the rev is... "rougher"?
Thanks in advance.
Thanks in advance.
