Rough Ride!
  • Cyrano
    • 163
    Rough Ride!
    Hey guys, I have a 88 E30 with 16" wheels, H&R E30 M3 springs and Blistein HD shocks. My problem is that i feel as if on a bumpy road I get no absorption, as if riding on metals all day. My other problem is that the car feels to bouncy.
    I use the car for every day driving, I like to have a stiff suspension, but the one I have now is just way too much. Can you guys suggest a suspension setup that will cure these problems.
  • Sagaris
    • Sep 2009
    • 2243
    Check first to see if the lyf3styl3 krew removed your rubber spring pads. I wouldnt imagine that setup being harsh unless you had no spring pads, polyurethane bushings, or 40 psi in your tires
    • whodwho
      • Jun 2008
      • 1547
      Bilstein HD shocks/struts are standard length and you maybe bottoming those out if you are much lower then stock on those springs.
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • Philo
        Ich esse kleine Kinder
        • 3334
        I would like to add that if your suspension feels 'bouncy' then you most likely have some blown dampers. I would check those as a starting point.
        -tim
        Originally posted by Jordan
        I like the stance
          The springs and shocks aren't extreme and shouldn't result in all that harsh a ride. The wheels, on the other hand, have little sidewall and will make for a rougher ride. Throw a set of OE wheels & tires on and see how they are.
          • StereoInstaller1
            GAS
            • 22679
            Pitch those shitty Bilstein and get a set of KYB: GR2 in front, Gas-a-just in rear (all they make for E30) and with the M3 springs you will have a nice, comfy-yet-sporting ride, not the bulldozer quality ride Bilstein gives you.
            Closing SOON!
            Thanks for 10 years of fun!
            • StereoInstaller1
              GAS
              • 22679
              oh yeah, all the fanbois here will buy your leftover Billies just as soon as you discover how shitty they really are.
              Closing SOON!
              • F34R
                sLaughter
                • 12376
                I love my dump truck ride...eats the shit out of just about anything in the corners.
                B-sports> B-HD
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • Cyrano
                  • 163
                  I thought the M3 springs and Billy HD shocks work well together. The bottoming out is when using H&R sport with HD shocks...
                  I check the air pressure and the rear tires were at 40psi, so put them down to 32. The ride is a little better, but still over bumpy road the ride is harsh.
                  Will check bushings next.
                  • whodwho
                    • Jun 2008
                    • 1547
                    Honestly I'm not sure that is your issue, I had seen the H&R springs and was mentioning if you are any lower then stock height that maybe stock length shocks/struts might be bottoming out.
                    • iamsam
                      • Jun 2008
                      • 176
                      I have H&R Race, Billy Sports, and 15x7 Kosei K1s with 205/50/15 tires, and the ride is great. I actually wish i had stiffer suspension like coilovers.
                      • Cyrano
                        • 163
                        I inspected the front shocks yesterday, and the spring pads seem are coming out of place. Maybe this is why
