I wanna say its the csb. It vibrates hella bad during acceleration but holding speed or slowing down its fine. but the issue is that the CSB feels solid. Any other ideas?
vibration when accelerating
Manual or automatic? What happens when you put it in neutral? Does it happen all the time or only at certain rpm's? How are you "testing" the CSB that it feels solid?
MattMatt
Originally posted by slammin.e28guyI pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.Originally posted by kronustry whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"Originally posted by chadthestampedeThis is like a reverse build thread; it starts out nice and gets shitty.
A vibration or noise from what seems to be under the car when accelerating that goes away if you lift off the throttle is most commonly from the drive shaft. The cause will be a failure of the rubber mount of the CSB, which in turn is caused by binding u-joints in the drive shaft. The fix is to replace the drive shaft and CSB (and probably the guibo) at the same time. Replacement of only the CSB may result in temporary relief, but until the drive shaft is replaced the new CSB will have a short life.The car makes it possible, but the driver makes it happen.
