WTF is this in my trunk
  • Bglad
    • Jul 2010
    • 562
    So I gutted my trunk out and am in the process of pulling all the non essential wires, and I noticed a couple of them running to a control box/relay of some sort in the trunk it's mounted on the driver side, with two plugs going to it it's about 2x5 inches, anyone know what this does?? Can I pull it?? Thanks! Pics Below....
  • blocke
    • 1305
    Is that the control box thingy for the active check control to check lights?
    Post up a pic
    Parts Wanted
    The Never-ending Resto Mod
    • daniel
      • 6703
      DON'T TOUCH IT THe WHOLE CAR WILL EXPLODE!!! BOOM
      http://instagram.com/dslovn.drives
        That sounds like it is the light warning module for the Check panel. Leave it in. It can be deleted, but you'll have a bunch of splicing to do to have the taillights & such work.
        • Bglad
          • Jul 2010
          • 562
          Cool, thanks for the replys. I think I'll leave it for now. maybe if I get bored between now and April I'll delete it.
          • AndrewBird
            The Mad Scientist
            • 11898
            Could also be the stock stereo amplifier. It's mount on the driver side near the antenna.
            • F34R
              sLaughter
              • 12376
              Good thing, wait till April and then remove the SUPER heavy wires. They must be a few ounces total.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • Bglad
                • Jul 2010
                • 562
                I'm not removing them for weight, I'm removing them for simplicity. The less wires and relays I have running in the car the better. Especially if they're not being used.
                • ///digitalme
                  • Dec 2009
                  • 2088
                  picture?
                  • Bglad
                    • Jul 2010
                    • 562
                    This
                    • ///digitalme
                      • Dec 2009
                      • 2088
                      wtf i have never seen that i need to check if my car has it...i know i have some random cables there from the po trying to install a smaller antenna
                      • Bglad
                        • Jul 2010
                        • 562
                        It's mounted behind the antenna. No wires from the radio or antenna ran to it. The box says lampkontoler.... some german crap. It's tied in with the tails some how, cause if I unplug it I lose them. Is they're a diagram for removing it anywhere?
                        • unrlmth
                          • 467
                          Thats right next to where the jack goes right? If it is then my 89 definitely doesn't have that.
                          1989 325i Alpineweiß II
                          • bzboardz
                            • 1096
                            I no expert but to me "lampkontoler" sounds like lamp controller
                            • unrlmth
                              • 467
                              Maybe taillights :)
