Hey guys bit of a problem with the m20 today.
I replaced the temp sender/switch the single probe one. And all was well topped up the coolant a bit and went for a drive temp was good gauge was reading. Then i let it sit for a couple of hours. Took it for another drive still good. Then gave it a bit onto the highway and noticed the gauge was pegged so pulled over straight away and had a look. No leaks still full of coolant and the temp wasn't that high. Like i put my finger in the coolant and it was hot but not boiling. I noticed there wasn't much pressure in it though. So i gingerly drove it home and disconnected the sensor it dropped to nothing. And check my temp send got a reading of 270ohms.Then i let it cool for an hour till the gauge read under blue. Started it up fans working, checked all my hoses and they aren't very pressurised but i noticed the one going to my thermostat was pressured after i let it cool down so its getting pressure and i checked my fan play and its ok. Could it possibly be a faulty sendor? or any ideas its my dd so i need assistance asap :)
