Rough Start
  • thirdirev
    • 101
    Rough Start
    Did some looking around, but couldn't find anything.
    When I try to start my car it'll just crank until I pump the gas a couple times. After it starts it'll idle at 600 for about 5-10 mins of driving before it idles more towards 1000 and stays steady. I was thinking a couple things, either the idle was off or the fuel pump/filter needs to be changed. I just wanted to get some input before buying things that aren't needed.
    A fuel system problem is a possibility, which you can diagnose via the tests in the Bentley manual. But my first suspicion would be intake leaks, which are best diagnosed by having a smoke test run on the intake.
    • thirdirev
      • 101
      Took off my ICV to clean it and see if that would help out at all and discovered that the PO stuck a penny in one of the hoses and had it completely blocked off. The ICV is shot so I'm gonna get a new one sometime down the road, just adjusted the throttle cable a bit, works for now.
