floppy clutch pedal
    floppy clutch pedal
    So my clutch pedal is losing pressure. I changed the slave. then i changed the clutch master. no change. Leaky line from the master to the slave? thats what i think and i believe its isolated there because the brakes are fine. any other ideas?
    Did you bleed the slave ?
      yep. bled after the slave swap and the master swap
        Does it get better if you pump the clutch? Does it get worse as it gets hotter?
          before i changed the master pumping helped. now if I keep my foot on the clutch with even a little tiny bit of weight i can feel the pedal slipping to the floor. but if i push it to shift then get away from it the pressure builds and it feels like nothing is wrong.
            anything?
              If you rub your balls hard enough you won't need to shave
              Closing SOON!
              Thanks for 10 years of fun!
                ahhh good point luke. ass lol
