--european car's BMW Tech Letters--
Alright, so everyone knows that M3 cams go in M50TU, and TMS offers a chip tuned to take advantage of them. If you have a M50 (non-vanos), with 252/240 or 256 / 240 timing, what are your options for chips? The plain M50 TMS one?
I'm asking because I'm looking into engines for sale. I of course, like the ease of M3 cams, but Schrick 252 or 256 would also work.
The cams are long down the road, but they depend on the choices I must make sooner. That choice is what engine to get.
Stu recommended jumping on a complete engine with all the accessories and wiring harness. I found this:
I've emailed the guy just now seeing if its still available. I also asked if he by chance could put on a 525 oil pan. But everything seems to be there, and low miles, and fair price. (And TMS chip already!)
BMW Cam Swap
Do 1996-99 M3 cams work in the M50 engine?
We spoke with Pete McHenry of Precision Performance in Winston-Salem, North Carolina. McHenry is a well-known expert on BMW engine swaps and parts interchangeability. He advises: The M50 2.5-liter VANOS cams are 228-degree duration, while S53 3.2-liter M3 cams are 252 intake and 240 exhaust. They fit fine and give a nice boost to the top end on a 2.5-liter M50. You can use the S52 cams with the M50 lifters and springs. The S52 uses smaller lifters (33mm vs. 35mm diameter) and conical valve springs with teeny retainer washers. Net saving with this stuff is 20 grams per valve. Get the S52 cam trays, lifters and springs if you can but the swap is OK with cams only as mentioned earlier. If you have a 1992 M50, you can switch the intake cam to the exhaust. Timing is 240 on both, but the intake has 9.7 lift vs. 9.0. Buy a 252 Schrick intake cam and you have the same cams as an M3 and only have to buy one camshaft.
--Mike Miller
--Mike Miller
m50 motor from a 92 325i. Comes with intake and exhaust manifolds, trottle body, all acc(ps, ac, alt), air meter, wiring harness made to fit 87+ e30s, DME/ECU with conforti chip, starter and light weight single mass BMW flywheel(can use e30 m3 clutch with it). Motor runs well and has about 100k miles. Makes an awesome swap into an e30! Asking $1,000. Shipping available from TX or pickup and save $100.
