How to check temp gauge?
  • Bimmerfanatik
    • May 2004
    • 5349
    Ok, I tried throwing another VDO temp gauge I had into my Motometer cluster, and it ain't workin. Now Jordan said they should be interchangable. Giving him the obvious earned benefit of the doubt, how do I test a temp gauge out of the cluster to make sure it's working? Send a constant signal or something I assume?
  • Jordan
    • 12916
    the center terminal is ground. give 6volts at one of the other 2 and see what happens. Should bring it to half way.
    https://mtechniqueabs.com/
