1986 325 (american e model) oil light came on yesterday checked oil and was a little above the add mark so i figured that in the next couple of days i'd go buy a quart and top her off. Went to start my car this morning pumped the gas three times and turned the key. Car dosen't catch and makes a screeching sound because i have a chipped tooth on my flywheel (this happens ocasionaly). So i pop the hood get out into the pouring rain and crank the engine a little by pulling on the alternator belt. I got back in the car and turned the key. The engine is cranking and usually it takes about 4 to 7 seconds to start when cold. Engine keeps cranking and cranking and dosent start. So i get out and start checking for losse wires or anything silly that might be keeping the car from starting. I checked the oil and it is now below the add mark. car will not start. What are your thoughts?
Another My Bimmer Wont Start Thread
Pumping the gas pedal only opens the throttle plate. If you do this prior to turning the key it won't have any effect. Either way the car should start right up without having to play with the throttle. Check to see if it's getting spark and fuel. If it generally takes a few seconds to start then I'd lean toward a fuel delivery issue. Bentley has the procedures for diagnosing these problems.sigpic
