Hey rev,
Here's the deal, I bought a 1991 318is cranks and won't start, the guy I bought it off of replaced the crank sensor and cam sensor also the fuel pump..*note* fuel pump doesn't prime when key is turned..
Here's a list of things I did:
Tested all power and grounds on the engine harness back to the ecu
Checked relays and fuses
I'm thinking it could possibly be the crank sensor, ignition coil or ecu..
Any input or diagnostic ideas would be greatly appreciated!!
