rear hydraulic distribution nut size
  • dlmrun2002
    • Apr 2007
    • 808
    Trying to get to some leaky brake lines fixed. Right rear side on 325iX. Pain in the ARSE. What size nut holds the hydraulic distribution block on? It is so rusty I can tell if it is a nut or not.
    Doug M ny country
  • dlmrun2002
    • Apr 2007
    • 808
    So the right line that curls back over the diff and goes into the distribution block is toast. The other problem is you can't unscrew where it goes into the distribution block because the head is all rotted off and there is really no clearance unless you remove the distribution block plus the other two lines that go into the distribution block. AND the nut or screw(phillips) that hold the distribution block to the floor is toast also. I do 99% of my work on my cars but this want has got me wondering. Maybe I'm getting to old for this....
    cranky ole doug
